TwinTurbo.NET: Nissan 300ZX forum - Re: Balance tube leak is one guess. There's a bracket
95TTurboZX
on September 30, 2013 at 7:09 PM
posted by jzack
on September 30, 2013 at 06:37 PM
I know the bracket you are talking about, it was installed correctly. Would an air leak cause it not to idle at all? I was thinking maybe some thing to do with fuel pressure?
What have I done
95TTurboZX
18:15:34 09/30/13
jzack
18:37:19 09/30/13
Re: Balance tube leak is one guess. There's a bracket -
95TTurboZX
19:09:06 09/30/13
Re: Re: Balance tube leak is one guess. There's a bracket
PYROhafe
07:34:47 10/01/13
shouldn't need to gap the standard NGK plugs..
Medallion Man
09:22:56 10/01/13
Re: shouldn't need to gap the standard NGK plugs..
-Grimm-
13:23:04 10/01/13
Re: Re: shouldn't need to gap the standard NGK plugs..
95TTurboZX
14:48:14 10/01/13
Re: What have I done
95TTurboZX
19:19:38 09/30/13
Did you clean your IAV connector?
-Grimm-
13:24:02 10/01/13
Re: Did you clean your IAV connector?
95TTurboZX
14:50:16 10/01/13
Solved, maybe almost
95TTurboZX
15:00:03 10/01/13
You need to clean the IACV and connectors
-Grimm-
16:41:09 10/01/13
Re: You need to clean the IACV and connectors
95TTurboZX
18:24:29 10/01/13
